b16/18 radiator hose?
Old Sep 19, 2014 | 03:47 AM
anthony_ek4's Avatar
Default b16/18 radiator hose?
Hi, I've done some research and I can't find a straight answer anywhere! I just bought a new alloy radiator for my ek4, I was going to get new radiator hoses while I was at it but my b16 is blowing a lot of smoke and has a bit of a knock coming from the bottom end, so I bought a b18c2 bottom end which I'm going to rebuild (I'm sure I'll have more questions on this later!) What I was wondering is, will b16 hoses go onto a b18? I know one hose goes into the head and another goes into the block, is this the same position on both motors? I'm not a complete noob but engine swaps aren't exactly my specialty! Thanks for any help!
Old Sep 19, 2014 | 04:27 AM
tony_2018's Avatar
Fish Twig
Default Re: b16/18 radiator hose?
Wrong. One hose goes to the head and the other hose goes to the thermostat housing. If your car came with a b16 than use a b16.
Old Sep 19, 2014 | 04:58 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
To answer your question..... yes the lower will work and if you are still running the b16 head the upper should as well but if you are running the gsr head then that hose is a little different
Old Sep 19, 2014 | 03:34 PM
Yes the thermostat housing, on the block, thanks, I will be using the b16 head, cheers! Are the b16 and 18 thermostat housing the same?
Old Sep 19, 2014 | 05:11 PM
tony_2018's Avatar
Fish Twig
Check honda parts site to confirm part # difference.
wunfstgsr
Dec 7, 2009 01:44 PM
StolenTeg
Nov 18, 2007 02:30 PM
90crxdxb16
Sep 18, 2006 02:13 AM
spaceman
May 4, 2004 03:20 PM
