little bit of research
Old Sep 16, 2014 | 05:52 PM
TheRookie74's Avatar
Default little bit of research
Hey guys im wanting to know if I can undo the top of the strut and remove the strut with dropping lower control arm heres what Here is what my Chilton manual says:
1. Disconnect the negative battery cable. If equipped with an air bag, properly disable the SRS.
2. Raise the vehicle and support it safely. Remove the front wheels.
3. Properly support the hub and knuckle assembly with a jack. Use a ball joint separator to disconnect the lower arm ball joint. Be careful not to damage the seal.
4. Remove the stabilizer bar retaining bolts
5. Remove the bolt securing the damper fork to the control arm.
6. Remove the lower pivot arm.
7. Remove the lower arm. Check the bushings carefully for wear or deterioration. Replace the bushings if any wear is found. Even if the bushings are not replaced, clean the centers and the bolt shafts.
8. Install in reverse order. Tighten the lower control arm to chassis bolt to 40 ft. lbs. (55 Nm.)
9. Properly enable the SRS system, if equipped, and connect the negative battery cable.
"Chilton Manual for 84-95 Honda Accord/Prelude"
will this work to remove strut without taking the wishbone loose?
its a 1991 Honda accord ex
Old Sep 17, 2014 | 05:39 AM
Fitz Williams's Avatar
10 Year Member
Default Re: little bit of research
No need to drop the LCA. When the fork is unbolted from the shock, it will come off and make room for the shock and spring to come out.
blueBB4lude
11
Jul 30, 2009 09:14 AM
RTW DC2R
Feb 23, 2007 07:30 AM
miguelv0723
Nov 11, 2006 04:26 PM
^Sammy]!.
Sep 22, 2003 05:47 PM
ddua
Aug 23, 2003 10:42 AM
