97 civic b18a1 swap wiring help
Old Sep 15, 2014 | 09:42 PM
DHGsRaphael's Avatar
Default 97 civic b18a1 swap wiring help
i just bought a b18a1 engine wiring harness but notice that the d16 wiring harness goes straight to the ecu and the b18a1 one doesn't it has a clip is there a way around this by splicing the wires and connecting it to the ecu or am i screwed and need to find a d16 wiring harness ? really dont want to get rid of this car but im to the point were im going to sell it
DHGsRaphael's Library | Photobucket
Old Sep 15, 2014 | 09:48 PM
Default re: 97 civic b18a1 swap wiring help
i put 98 instead on 97
Old Sep 18, 2014 | 05:50 AM
Trey's Avatar
25 Year Member
Default Re: 97 civic b18a1 swap wiring help
You would use your Civic engine harness on a B swap engine.
Good info: http://www.ff-squad.com/tech/
Old Sep 18, 2014 | 09:33 AM
EsotericImage's Avatar
Retired Moderator
https://honda-tech.com/honda-civic-d...-vtec-2987229/
just needed to search
Old Sep 18, 2014 | 10:10 AM
tony_2018's Avatar
Fish Twig
You can't use the integra engine harness on this generation civic. You'll need to reuse your civic engine harness.
Old Sep 18, 2014 | 04:57 PM
HondaPartsHero's Avatar
Technical Hero
Plus I hope your B18A1 is the OBD1 version because otherwise you can't use a few components such as the distributor and injectors if not.
DHGsRaphael
Sep 10, 2014 08:38 PM
lsvtek
Nov 3, 2008 10:29 PM
crawdaddy169
Mar 28, 2006 04:01 PM
98b18black
May 7, 2005 08:37 PM
