2000 Civic Si no spark, coil/ICM tested good
Old Sep 15, 2014 | 12:47 PM
dwillms's Avatar
Default 2000 Civic Si no spark, coil/ICM tested good
Struggling to figure out this no start.
2000 Civic Si (SiR, since I'm in Canada)
- Cranks but won't start
- Has fuel, no spark at any of the plugs
- Timing belt not broken & timing marks line up
- Checked all grounds, G101 thermostat ground is tight
- Main relay fine, fuel pump primes, CEL turns off after 2 sec & no codes
- Checked all fuses, battery fully charged
- Tested +12V at Blk/Yel wire to distributor
- Primary coil resistance 0.7 ohms, secondary around 14K ohms
- ICM tested fine
- Checked plug wires in correct order on distributor
- Cap & rotor replaced with newer ones, plugs were wet with fuel & replaced with new ones
The only other ideas I can come up with are bad ECU or crank sensor.
Any help would be greatly appreciated, thanks!
-Dustin
Old Sep 16, 2014 | 03:27 AM
Civic Racer X 7's Avatar
Default Re: 2000 Civic Si no spark, coil/ICM tested good
I had this happen after I changed my ignition control module
Somehow I got the wires mixed up.
My test light showed power to the positive size AND the negative side of the coil
I corrected the connections and it fired right up
Old Sep 16, 2014 | 03:31 AM
Confirm this
Old Sep 16, 2014 | 06:50 PM
dwillms's Avatar
Originally Posted by TomCat39
Pulled the link directly from the FAQ stickied at the top of this forum Under Diagnostic's, How to diagnose your no spark problem:
https://honda-tech.com/honda-civic-d...blems-2919450/
But buy the sounds of all your tests, do you have a spare ECU to throw in to test?
I followed all the steps in that thread & came up empty, which is why I started this thread.
I might have a spare ECU, if I find it I'll try it.
I checked & all 4 wires were reconnected to the ICM correctly.
votex5
Jun 13, 2013 11:51 AM
wicked00
Dec 20, 2012 11:22 AM
dreakob16a
Nov 30, 2011 02:58 PM
20sir00
65
Apr 7, 2010 03:25 PM
92eh3
Nov 13, 2008 10:03 AM
