91 Sedan Heater problems
Old Sep 14, 2014 | 02:46 PM
mrboompow's Avatar
Default 91 Sedan Heater problems
I have a 91 Sedan LX model. When i bought the car the heater worked but now it isnt working. The blower isnt coming on. Ive checked fuses that seem like they would be for the heater and still nothing. Any ideas?? winters coming up and i daily her.
Old Sep 14, 2014 | 06:44 PM
99teggsr's Avatar
Default Re: 91 Sedan Heater problems
Crawl up under glovebox and give the bottom of heater blower motor a good whack while it is on. If the motor is on its way out due to worn brushes this will usually get it to spin a little bit to verify you have power to the blower motor. Or if you have a meter you can check for 12VDC at the 2 pin blower motor connector while the heater is on. If you have no power to the 2 pin connector it could be broken heater blower resistor, broken climate control or a break in a wire somewhere.
Old Sep 15, 2014 | 12:15 AM
~sp33~'s Avatar
EFB055
The blower resisters often blow the lower fan speeds first (speed 1, speed 2) because they run thinner wire than 3-4. So if speed 4 still works, but the others don't - it's your resister.
Check your fuses as well as what 99teggsr suggested.
Old Sep 15, 2014 | 03:38 AM
mrboompow's Avatar
is there any fuses that may do it that dont say anything close to heater stuff?/
Old Sep 15, 2014 | 11:43 AM
sodaZC's Avatar
No check the resistor like they said above. it takes like 5 minutes. dont be hard headed/lazy.
The Seller
Jan 28, 2014 05:25 PM
LATINOSPEED
Aug 1, 2007 09:06 AM
who-got-rice
Mar 23, 2005 05:48 AM
bodiez
Jan 6, 2005 05:22 PM
bodiez
Aug 27, 2004 05:34 PM
