Spark plugs!!!!!!!!!!!!!!!
Old Nov 1, 2002 | 04:19 AM
CTR94Joes's Avatar
Default Spark plugs!!!!!!!!!!!!!!!
Ppl that have a GSR which NGK spark plug do you use. I'm using PFR6G-13 for right know but i'm going to use BKR6E-11. But I need to know which gap setting to us on these plugs (BKR6E-11).
Old Nov 1, 2002 | 07:17 AM
IN VTEC's Avatar
Default Re: Spark plugs!!!!!!!!!!!!!!! (CTR94Joes)
PFR6G-13 (VTEC stock platinums)
I might have to switch up to heat range 7 b/c of the CR increase.
Old Nov 1, 2002 | 07:32 PM
araknis's Avatar
New User
Default Re: Spark plugs!!!!!!!!!!!!!!! (IN VTEC)
I'm using the platinum ngks right now, but i just bought some bkr6e-11 to replace them.. the platinum ones are $25 at pep boys and the copper ones are $1.49.. crazy..
btw, i would like to know the correct gap setting as well for the copper plugs..
Old Nov 1, 2002 | 08:13 PM
IN VTEC's Avatar
1.3mm
Old Nov 2, 2002 | 08:58 AM
Web_Head's Avatar
New User
Use Bosch Platinum +4. I noticed a difference in passing power on the highway after putting them in my 96 Integra SE
Old Nov 4, 2002 | 07:58 AM
CTR94Joes's Avatar
Default Re: Spark plugs!!!!!!!!!!!!!!! (Trench)
I think i'm going back to the Bosch's, I felt power with them, more with the copper NGK's. Or I might try the plat NGK's. I set my NGK cops at 1.3 and to me, vary bad for my setup. I goota try the Plat's NGK's and see how those work for me. If not then it's back to the Bosch's. I had the 2way Bosch's and the power was there, so go figure.
Old Nov 4, 2002 | 08:07 AM
eh-D's Avatar
I leave the BKR6E-11 at 1.1 mm. I've never had any problems.
Markov
Oct 7, 2005 10:33 AM
631 Teggy
Jun 1, 2003 06:28 PM
PTownGSR
Jun 5, 2002 05:14 AM
