Cleaned the IAC Valve but now idle worse
Old Sep 13, 2014 | 01:12 PM
shumanfoo's Avatar
Default Cleaned the IAC Valve but now idle worse
Help!
I just cleaned my IAC Valve on my 1996 Honda Accord EX. took it out for a test spin and now it seems worse. keeps stalling out on me.
Is there something else I can do to get it back to running?
Thanks.
Old Sep 13, 2014 | 01:53 PM
holmesnmanny's Avatar
Default Re: Cleaned the IAC Valve but now idle worse
If you cleaned the iacv and the issue got worse you now need to replace the iacv and see if that was the original problem.
If you sprayed carb cleaner inside while it was hot it's likely the seals swelled up and the iacv has become junk.
You should always only clean the outer metal mesh filter. I never suggest spraying anything other than water inside.
Old Sep 13, 2014 | 02:27 PM
HondaPartsHero's Avatar
Technical Hero
Did you remove the Oring inside? You may also need to relearn your idle a well.
Old Sep 13, 2014 | 04:57 PM
94 accord typeR's Avatar
google search. plenty of ppl have cleaned the IACV and had bad idle after if they didnt let it dry before install. i also saw plenty of ppl have issues after adjusting the FITV so i decided to leave mine stock
Old Sep 15, 2014 | 11:07 AM
therhett17's Avatar
Originally Posted by shumanfoo
Help!
Thanks.
Exact same thing happened to me after I cleaned mine. The following fixed it: On a cold engine, unhook the battery for a few minutes then reconnect it. Start the car and hold RPMs at 3k for about 5 minutes. Shut off the car, then immediately restart it and let it run for about 10 minutes. This is supposed to reset the ECU and let it relearn the idle (simply unhooking battery usually doesn't work in this case). Good luck!
23nesnes
Sep 22, 2009 10:21 AM
Praetor353
Apr 28, 2009 03:59 PM
SlackerAccord
Sep 22, 2005 08:49 PM
GreensleeperB16
Aug 5, 2003 07:41 PM
willyboyK20
Jul 25, 2003 11:26 PM
