Honda civic si vibration
Old Sep 13, 2014 | 07:18 AM
Em1-2000's Avatar
Default Honda civic si vibration
So last night I changed the top driver side motor mount, then I started the car up and it vibrates even worse now. I used an oem mount so no poly or solid mounts. My uncle who helped jacked the motor up on the crank pulley 😭 so now I think that's causing my vibrations when I drive. Or could it be the other mounts??
The motor is a b16 usdm
Old Sep 13, 2014 | 05:09 PM
94 accord typeR's Avatar
Default Re: Honda civic si vibration
Honda Civic/Del Sol (1992 - 2000) - Honda-Tech
wrong forum
"jacked the car up by the crank pulley"? that would cause everything to misalign OUCH
Old Sep 14, 2014 | 11:40 AM
strategy400's Avatar
I would take a look at the crank pulley while the engine is running. Also, you may just need to loosen and retighten all the mounts to let them align properly. I believe there is a procedure for this in the helm manual for accords, not sure about civics.
Old Sep 14, 2014 | 01:34 PM
NerfGunner420's Avatar
**** yeah. who the ***** lifts a motor from the crank pulley anyways
Em1-2000
Sep 15, 2014 02:28 AM
Hondacivic90ed
Aug 11, 2012 05:41 PM
RAB
Oct 13, 2004 05:45 PM
Turbolude
Sep 12, 2001 05:53 PM
