96 accord crank no start.... no idea
Old Sep 12, 2014 | 01:29 PM
syber's Avatar
Default 96 accord crank no start.... no idea
I have a 1996 standard transmission accord ex coupe f22b1.
I use the car for delivery driving. Full synthetic, 87 gas, seafoam a week before oil changes, i baby it a bit.
Drove it all day parked for an hour then wouldn't start. Sounds exactly like it always dose just doesn't start.
Here's what I'v done
CChecked fule relay
Checked fule filter for presuer
Batteries good
Alternator good
New spark plugs and wires
Distributor looks good
I'm getting spark
Replaced starter had bad terminal.
Checked clutch safety switch...
All good
Still will not start any ideas?
Old Sep 13, 2014 | 12:49 PM
syber's Avatar
Default Re: 96 accord crank no start.... no idea
Any ideas
Old Sep 13, 2014 | 01:57 PM
holmesnmanny's Avatar
Is it cranking or not ?
Old Sep 13, 2014 | 02:35 PM
NerfGunner420's Avatar
are you getting fuel into the cylinders? getting fuel pressure is one thing. but do the injectors fire?
Old Sep 13, 2014 | 04:55 PM
94 accord typeR's Avatar
CChecked fule relay
when u checked the fuel relay/main relay the only way it would check out is because the solder joints wernt bad at the moment. when ur car heats up due to driving or sitting in the sun the solder joints disconnect leaving u stranded. the main relay controls plenty of components including fuel pump, fuel injectors, ECU, just to name a few.
Old Sep 13, 2014 | 10:30 PM
chrisnick's Avatar
This. Check ignition cylinder, too.
mete4d
Jan 19, 2018 12:23 PM
pinggoy
Nov 24, 2009 02:53 PM
samvilay
Oct 31, 2009 02:46 PM
03PackEngr
Feb 25, 2008 05:11 PM
91GreyAccord
Jul 20, 2002 11:09 PM
