Dpfi to Mpfi harness question
Old Sep 11, 2014 | 11:33 PM
fiction1990's Avatar
Default Dpfi to Mpfi harness question
I keep seeing to use an si harness for plugs. My question is if I can find a 91 EF ex will that harness plug directly into my 91 EF DX harness or is it the same thing as the si harness where I just need plugs off of it? Or will any d16a6 work for example 92-95 they are in abundance at pick apart.
Old Sep 12, 2014 | 03:58 AM
Freemananana's Avatar
Default Re: Dpfi to Mpfi harness question
Any of the plugs will work from a MPFI motor. You have to modify your DX harness though. The Si or Ex harness will not plug into the harness at the shock towers.
Old Sep 12, 2014 | 05:12 AM
Thank you, that's what I needed to know
Old Sep 12, 2014 | 06:03 AM
edvas1's Avatar
Very easy to do. There are companiesthat sell plug n play harnesses for like 160 but if you run new injector wires and the 2dizzy wires the rest is just extend wires and solder a new dizzy plug
EFing_Slow
Nov 1, 2016 06:41 AM
bradpee
Aug 31, 2009 08:25 AM
yz125rider21
Feb 5, 2007 12:13 PM
elmalouno
Apr 26, 2004 02:35 PM
ITR981002
Jan 27, 2004 07:48 AM
