b18c5 obd2 harness into em1 p2t ecu.
So I just bought a obd2 harness of a b18c5. Would I be able to use it on my 00 em1 with a p2t ecu.
Would I need a sub harness ?
What else would I need.
It's going to be a B20b/B16head
Thanks in advance.
Thanks in advance.
Cool Cool Island Breezes. BOY-EE
No. The EM1 uses a 1pc harness that is totally different from an integra harness. Why are you changing harnesses?
I bought the car without a harness. And been looking crazy for one. If u guys k ow where or Blagojevich has one that would be appreciated. And there's no way for my to use this harness at all?
If you weren't sure you should've asked first before purchasing that integra harness.
edit: And if you decide to use a honda civic ex harness to work with your engine setup just make sure its obd2b and buy the appropriate dsitributor harness.
Blagojevich is in prison for a bit. He hasn't sold a harness for a few years.
Sounds like he needs an entire harness though. EX will be much easier to find just make sure it's 99-00 and do the distributor adapter for plug and play.
car-parts.com. Find one with a grade A rating, call and verify with the seller the price, and that no wires/plugs are damaged. I've had luck with a guy out in cali, they were very helpful. I've ordered 2 different civic harness from that site.
Get a harness made Rywire Motorsports Electronics : Home
jdmekrobot
Mar 13, 2008 12:13 AM
endlessdv
Feb 6, 2005 12:17 PM
