What B16a/ distributor do I have?
Old Sep 11, 2014 | 01:59 PM
Civic Racer X 7's Avatar
Default What B16a/ distributor do I have?
Can you identify this distributor?
Was told it was an obd2 b16
Went to the honda dealership and got a 99 si cap
And it does not fit well , some parts line up but it's not an exact fit
And doesn't seal properly
Old Sep 11, 2014 | 02:01 PM
Default Re: What B16a/ distributor do I have?
Top view
Old Sep 11, 2014 | 02:22 PM
HondaPartsHero's Avatar
Technical Hero
Is your check engine light on?
Old Sep 11, 2014 | 02:27 PM
Not sure , the dash is gone
And ecu chipped with Neptune
Not sure how to tell
Would that cause it to bust up at 7000
Old Sep 11, 2014 | 02:59 PM
Need help identifying what distributor I have
Because the 99 si b16 cap from honda doesn't fit
Old Sep 15, 2014 | 03:42 AM
Going to return the cap to the dealer today, thought about trying an obd1
B16 cap
Maybe someone re pinned this dizzy?
Old Sep 15, 2014 | 04:09 AM
NotARaCist's Avatar
I never narc'd on nobody!
Given the bit of a clusterfuck that is your car, your best bet would be to remove the distributor, and take it to the dealership with you so they might be able to match up the correct part.
Old Sep 15, 2014 | 04:24 AM
NotARaCist's Avatar
Time out. How many threads are you going to start for the same thing?
https://honda-tech.com/honda-civic-d...iring-3222485/
https://honda-tech.com/honda-civic-d...start-3222666/
Old Sep 15, 2014 | 06:31 AM
TanEJ1's Avatar
Looks like obd-1 ... Look............http://www.rywire.com/obd1-to-obd2-8...-1-2-8-pin.htm Or it could be this one http://www.rywire.com/obd1-to-obd2-8...1-2-10-pin.htm In the picture you have 2 connectors from the Dizzy... Not one like obd-2..
JOS-EM1
Jun 5, 2011 07:23 PM
slowboy90
Oct 19, 2010 07:26 AM
mjrage
Jun 5, 2004 08:03 AM
