skunk cams and cam gears?
i just installed used cams and cam gears in my 2001 gsr, result= ***, when the vtec hits it just makes noise. it feels like i dont even got vtec. What the hell could be wrong, i need help. i was thinking the obd2 thing, i need advice. oh yea my cam gear is at 0. thnx for your responses
From what i have read from others who have experienced similar things, I would bet that you installed "stage 2" - am i correct? that level of cam requires more CR and makes its power higher in the rev band...you'lll need a lot more than just a vafc to get the most from those...more like pistons, ecu, valvetrain plus what you got.
ok, i jus added the obd harness with a obd1, plus short shifter, short shifter bushings, aem cold air intake, nologys, dual n-1`s, skunk cams, and skunk cam gear. AND IM FUKING CLOCKING 16.2
im jus disappointed. i should have jus kept my Si. from 5 to 6 rpm my car doesnt move but once it hits 7 to 8 damn that ***** pulls like a mother
i was gettin spanked by civics
sigh ill try the vafc and manifold, see if that helps. if not, looks like time for a new car
you must have money out the bling like that.....
try to get the VAFC and tune them. throwing those things in there wont produce much power without tunning, get it tuned professionally.
see the problem with hawaii is thaT ONE its a samll *** island and TWO aint no shop out here is a pro at tuning cars VAFC,GEARS, ETC. Well they claim there is but i dont trust them for shet, it looks like im **** out of luck
i think ill jus drive it into the ocean and insurance it
but ill take it to tracks next week, this time ill take my 3 12`s out of my car, i was thinking that big and heavy *** box could also be a problem
oh yea this is not racerman i forgot to log on as rolln
Get the VAFC, Fuel pressure regulator and guage.
Then take it to the dyno.
You don't want to hear this but..you should've saved your$$ and went with the Toda B's or Jun 3's. Skunk=Junk
comments like this are not helpful dood. before you put down a product, you should check out the gain #'s. i will tell you now that the stage 2 skunks are the same as the Jun3's and about 200 bucks cheaper
all 3 are good cams, it just depends on what ur planning. drag racing(top end)=JUN/Skunk2
road racing(mid range)= Toda
[Modified by MaliceGSR, 4:44 PM 11/2/2002]
dLo GSR-stolen-now-WRX
Dec 18, 2002 05:34 PM
