Installed LED brake bulbs, brake light out idicator on cluster, brake lights work
Old Sep 11, 2014 | 05:18 AM
96F20bAccordSir's Avatar
Default Installed LED brake bulbs, brake light out idicator on cluster, brake lights work
I suppose the problem is probably not enough resistance causing the brake lamp out indicator to come on. My question is.. How do I fix and if I need to place a resistor what type and where? I travel quite a bit and I use my cruise quite often. I need to fix this so the safety with is not triggered. If there is a work around that anyone can think of that also would be helpful. Thank You. Nate.
Old Sep 11, 2014 | 10:43 AM
Default Re: Installed LED brake bulbs, brake light out idicator on cluster, brake lights work
I think I found the solution. Need 50w x 6ohm load bearing resistors on each of the tail lights. Ill have to wait til I get paid to get some. Ill post if its a success.
Mishako129
Jun 4, 2013 10:50 AM
nicolaselias
Dec 22, 2011 03:58 PM
Egpower88
Nov 5, 2009 01:12 PM
hale_image
Nov 10, 2004 04:34 PM
