Mikey
Old Sep 10, 2014 | 11:21 AM
metazman2's Avatar
Default Mikey
I have a 92 accord when you turn the key to the on posistion there are no lights in the dash. Also there is no power to the fuse box inside the car. The main relay is good as are all the fuses under the hood and inside the car. The car will turn over and wants to start but won't. Am I missing another fuse or relay somewhere?
Old Sep 10, 2014 | 11:24 AM
Scolirk's Avatar
Default Re: Mikey
Did you check all the connections underneath the engine bay fuse panel? They tend to come loose, especially if the fuse panel is moved or unscrewed.
Old Sep 10, 2014 | 12:35 PM
metazman2's Avatar
Default Re: Mikey
Not yet but I will the car was running fine then went dead. I am thinking it may be a ground issue. They all seem to be tight. What is that relay connected to the back left of the fuse box?
Dnizzle
Mar 16, 2013 11:57 AM
JdmJah
Jan 8, 2013 10:25 AM
free99
Audio / Security / Video
Mar 6, 2007 12:14 PM
SLOW4drINTEG
Nov 13, 2003 08:19 PM
