Camber: switching wheels
Old Nov 1, 2002 | 12:27 AM
eg-r's Avatar
Default Camber: switching wheels
hey what's up
i have adjustable coilovers on my EG w/ 17's
and im getting my camber kit installed soon..
i also have a set of steelies for winter use and im wondering
how that will affect the camber when i put it on and also when
i put back the 17's after winter
Thanks in Advance
Old Nov 1, 2002 | 01:58 AM
texan's Avatar
Default Re: Camber: switching wheels (eg-r)
Camber is only affected when the overall diameter of the rim changes, and even then it's SLIGHT. If your wheel diameter is about the same with both setups, there's no reason to be concerned.
Old Nov 3, 2002 | 01:46 AM
eg-r's Avatar
Default Re: Camber: switching wheels (texan)
ohh i c so as long as the 14's and the 17's are the same diameter (with the tires it should be fine?)
if its not the same size would that fukk up one set or both set of wheels
would there be anything else affecting the camber? (ie replacing front brakes, adjusting coilovers)
sorry for all the questions
[Modified by eg-r, 7:15 PM 11/3/2002]
Tyte-S
Jun 12, 2008 08:00 PM
Sterndotstern
Nov 25, 2004 05:57 PM
CrX-To-Tha-Max
Mar 4, 2004 07:17 PM
JMD
Jul 16, 2003 05:56 PM
Chip398193
Jul 29, 2001 11:38 AM
