P72 GSR piston compression?
Old Sep 10, 2014 | 04:41 AM
EF'GSRrr91's Avatar
Default P72 GSR piston compression?
Wondering if anyone would know what the compression ratio would be for a set of jdm p72's oversized 0.50mm?
Old Sep 10, 2014 | 06:42 AM
93egSLEEPER's Avatar
Default Re: P72 GSR piston compression?
What block, crank and rods are they going with?
Old Sep 10, 2014 | 06:57 AM
AllMtrRex's Avatar
Originally Posted by 93egSLEEPER
What block, crank, cylinder head, valves, head-gasket and rods are they going with?
Also, is there any milling or decking of head and block?
Old Sep 10, 2014 | 10:32 AM
I was trying to keep it basics for starters so we can get a baseline to work with. Don't overwhelm the guy lol
Old Sep 10, 2014 | 10:46 AM
AllMtrRex's Avatar
True. Although, he may learn something from the two posts and he may report back after doing research on his engine.
OP, rule of thumb, if going .50mm or .020" over bore on a cylinder this usually equates for roughly ~+.1 bump in static compression. (Example 10.6:1 STD vs 10.7:1 .020" overbore)
Old Sep 10, 2014 | 08:22 PM
EF'GSRrr91's Avatar
Yes I had the head milled and the block decked also. stock block, stock crank.
Old Sep 10, 2014 | 08:25 PM
EF'GSRrr91's Avatar
Stock gsr head, I replaced the valve stem seals.
Old Sep 10, 2014 | 08:28 PM
EF'GSRrr91's Avatar
head gasket is 81.5" .030" oversized
Old Sep 10, 2014 | 08:39 PM
EF'GSRrr91's Avatar
Forged h-beam scat rods w/ arp bolts... Lol
Old Sep 10, 2014 | 08:45 PM
EF'GSRrr91's Avatar
So roughly will I be running around 10.8:1-10.9:1?
Old Sep 10, 2014 | 09:29 PM
Depends how much your stuff was decked and milled. Bone stock it will be 10.7ish.
Just curious...why the rods?
Old Sep 10, 2014 | 10:06 PM
EF'GSRrr91's Avatar
Boosting next summer.
Old Sep 10, 2014 | 10:17 PM
EF'GSRrr91's Avatar
I forgot what the machinist said already, it was a few weeks ago, said he basically barely skimmed the head and block that they were in good shape. The oversized head gasket will make up the difference in the machining so ur right prolly right in that range. I appreciate the advise/help. First build, testing stuff out.
Old Sep 11, 2014 | 06:33 AM
If you're going to boost it and already have forged rods....why not do the pistons with them?
Old Sep 11, 2014 | 08:25 PM
EF'GSRrr91's Avatar
I did. The Jdm p72's 81.5mm bored .020".
Old Sep 11, 2014 | 08:26 PM
EF'GSRrr91's Avatar
I didn't go with forged pistons. Too expensive for this poor man build.
Old Sep 11, 2014 | 08:27 PM
EF'GSRrr91's Avatar
Everything's installed, just wanted a to get a rough estimate of the cp ratio
Old Sep 11, 2014 | 08:29 PM
EF'GSRrr91's Avatar
Nippon racing pistons and rings... the rods, pistons, rings came in a set for a decent price.
bigsnorlax
Sep 14, 2008 06:43 PM
johnzm
May 10, 2005 04:38 PM
Thrashin
Aug 10, 2004 02:41 PM
0bd1_Kanobe
Mar 19, 2004 01:30 PM
