ITR sway bars
Old Oct 31, 2002 | 11:55 PM
deviant1's Avatar
Default ITR sway bars
how big are the ITR sway bars - front and rear? or is there only a rear? i was thinking of getting the front and rear sway bar package from suspension techniques but im not sure which will perform better. anyone know how big the bars are from ST? which would perform better?
Old Nov 1, 2002 | 12:05 AM
Evil_Wizard's Avatar
Default Re: ITR sway bars (deviant1)
Yes they have front and rear sway bars. On the rear the sway bars are 22 mm in the US and 23 mm in Japan.
Old Nov 1, 2002 | 12:45 AM
Unjockable's Avatar
New User
Default Re: ITR sway bars (Extreme_Hybrid_Hatch)
i love the ITR swaybar. Get them.
Old Nov 1, 2002 | 02:21 AM
DSC's Avatar
DSC
If you get the ITR rear you should get the Beaks subframe kit just in case.
http://www.beakproducts.com
The ST rear one is pretty good too with the built in tie.
Old Nov 1, 2002 | 04:06 AM
BERT-O's Avatar
Default Re: ITR sway bars (Unjockable)
same here, rear 22mm ITR , stock EG fronts 21mm.
love them and a cheap upgrade.
Old Nov 1, 2002 | 05:54 AM
Eee Pee's Avatar
Default Re: ITR sway bars (SANBST)
Isn't the front a 24mm bar, like the GSR.
Old Nov 1, 2002 | 07:05 AM
Dorikamu's Avatar
Default Re: ITR sway bars (E Prep)
I am confused, if I have ITR rear LCA on my EG, do I still need the Beaks kit to install the ITR sway bar?
Old Nov 1, 2002 | 07:08 AM
cre18's Avatar
Default Re: ITR sway bars (DSC)
love my beaks kit
Old Nov 1, 2002 | 07:17 AM
B18C-EJ1
Guest
Posts: n/a
ITR/GSR front - 24mm
ITR, USA rear - 22mm
ITR, JDM rear - 23mm
Beaks kit is recommended on the rear.
Old Nov 1, 2002 | 10:28 AM
deviant1's Avatar
Default Re: ITR sway bars (B18C-EJ1)
these are going on a 96 EK hatch so what is needed besides the front and rear sway bars and beaks kit for the rear? is there a reinforcement for the front?
Old Nov 1, 2002 | 01:45 PM
EVIL Hx Coupe's Avatar
Default Re: ITR sway bars (proud BLACK honda owner)
Where can I get an ITR swaybar???
Old Nov 1, 2002 | 01:47 PM
EddieHatchBlack's Avatar
Default Re: ITR sway bars (Boost Pressure)
http://www.hondaautomotiveparts.com
http://www.beaksproducts.com
Old Nov 1, 2002 | 01:49 PM
Stock, a 96 DX has no front and no rear sway, so you don't wanna add a beefy rear without something for the front.
I recommend:
SI 26mm Front sway (you need dampening forks, and LCAs)
ITR 22mm Rear sway w/ beaks kit
You can also use a 21 mm (i think that's the size) EX front sway (you need LCAs I think)
Eddie
Old Nov 1, 2002 | 05:06 PM
racecarpete's Avatar
Default Re: ITR sway bars (Eddie HatchBlack)
Eddie
You are close man, eg front sway bar is 21mm, ek front sway bar is 22mm and yes he will need the front lca, actually half but let's not get into that.
Old Nov 1, 2002 | 09:43 PM
deviant1's Avatar
Default Re: ITR sway bars (SilverCivic2k)
if i replace my front LCA and forks, will i still be able to use my tokico illumina struts that i have for my stock suspension? rear too?
[Modified by deviant1, 10:44 PM 11/1/2002]
Old Nov 1, 2002 | 11:44 PM
http://www.beaksproducts.com/ek-quickswap.html
Will that work on a 96 HX coupe???? And does anyone know how big the front Hx sway bar is???? Thanks.
Old Nov 3, 2002 | 10:02 PM
deviant1's Avatar
yea, will the EK quick swap work on my 96 EK hatch? they say its only for the 99-00 Si. that would make life easier. it has all the parts i need for just the rear right? and its cheap. i added up all the parts i would need if i just bought the beaks kit and bought the rest from acura, the total was 220.14 without shipping. thats just the rear! so 160 sounds mighty nice!
OT: the suspension techniques front and rear sway bars are front: 1" and rear: 3/4". how big are those in mm? just for comparison against the type-r bars. so, does everyone recommend the type-r bars? also, will a rear lower tie bar work with the beaks type-r rear setup?
[Modified by deviant1, 11:22 PM 11/3/2002]
Old Nov 3, 2002 | 11:40 PM
It says for 99-00 Si because it utilizes 99-00 Si endlinks. It will work on your 96 hatch, all you have to do it buy that quick swap kit (the $160) and also buy 99-00 Si Endlinks.
nw dc two
Jan 7, 2007 01:59 PM
litterbox
May 19, 2004 09:21 AM
2lobes1engine
Apr 21, 2004 10:13 PM
