1997 Civic full transmission oil drain/change
Old Sep 8, 2014 | 08:31 PM
Nate Destructoh's Avatar
Default 1997 Civic full transmission oil drain/change
Recently bought a 97 civic automatic trans. It has 120k miles on it
I'm fairly certain the car was sitting in a few feet of water at one point which got into the transmission as the trans fluid is very dirty and murky (essentially grey) and water like. Shifts rough 1st and 2nd gear.
I'd like to completely drain all the fluid and replace it without doing a 'flush' as I'm worried it might not shift if I did that because I'm not sure how long this water/fluid mixture has been in.
Wondering what is the best possible way to go about this
Old Sep 9, 2014 | 03:04 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 1997 Civic full transmission oil drain/change
get that crap out of there immediately. flush it, use whatever method you can to remove it ALL. then, put in new fluid, run it a bit, drive a couple miles, and flush it AGAIN. refill with honda z1 or equivalent (ive had good luck with valvoline), and cross your fingers. that generation is not known for particularly good auto transmissions to begin with.
teknohatchie91
22
Sep 18, 2016 11:42 AM
Whited.97.EX
Jan 6, 2015 02:33 AM
northtexas
Honda Civic (2006 - 2015)
10
Sep 25, 2013 09:29 PM
eddieE
Feb 4, 2013 05:12 PM
Maurice24
Apr 30, 2010 12:39 PM
