2012 V6 Coupe turn signal flasher location ?
Ok I've just about removed the interior of my car looking for the turn signal flasher.
Does anyone know the EXACT LOCATION of the flasher?
I can hear it right up under the dash but can't put my hand on it. I bought a new flasher modified it with a .12 ohm resistor and want to try it for my hyperflashing led turn signals.
Help Please
Help Please
It doesn't have a traditional flasher relay that you could just pull and plug in like previous generation Accords.
The Turn Signal/Hazard Flasher Circuit is part of the driver's multiplex integrated control unit (MICU). The MICU is built into the driver's side under-dash fuse/relay box.
In addition, there is a Turn Signal/Hazard Relay 2 (sounder) built into the Gauge Control Module (aka instrument cluster).
Thank you. That would explain why I couldn't find the damn thing.
So that brings up another question why does Autozone sell a replacement flasher for a car that doesn't have one??
Another $20 wasted
Thanks
Another $20 wasted
Thanks
