B18b All Motor Build need opinions
I have a 1999 Integra LS I have owned for about 3 years. I am in the process of getting it ready for a huge car meet in March in my area. I'm about to pull the engine for a rebuild/refresh my oil control rings are getting worn while out I'm putting ARP bolts/studs in the rods and head. I was planning on going back with wiesco pistons and Crower 403 cams with a Blox intake manifold. I have a B18b block with a B20 head and cams currently. I want to achieve about 180whp but I've heard multiple comments about the non-vtec heads flow limiting usable power greatly. I wanted to get some advice on this build and try to decide to continue or take another route.
Price of a properly built Ls head> stock vtec head and required swap parts.
Thats assuming the bottom end is properly built first.
Im stickin non vtec cause im going boost eventually and I got a deal on a built ls head thats been ported decently
Thanks for all the advice I'm considering going ls/VTEC ive personally seen that setup put down over 200whp. I definitely don't wanna drop $1200+ dollars on the ls and not be satisfied
Disadvantages of LS build -
Shitty flowing head
You're always on the 'big lobe' so your idle will SUCK with any cam that makes power
You need pistons with valve reliefs
little to no intake manifold support
increased valvetrain wear
low power output for money invested
Advantages -
less moving parts
easier to tune
low entry price
Do the VTEC conversion man, you'll be happy you did.
Shitty flowing head
Advantages -
less moving parts
easier to tune
low entry price
All pistons need valve reliefs. Even the stock ls pistons have little reliefs in them.
Ive never heard of worse valvetrain wear to be honest.
The other con you didnt mention is the poor rocker design that likes to pop off above 9000rpm.
it can be done...if you dont mind running premium gas (93+) or E85 and tuned/modified ECU you can def do it - CTR pistons will bring the compression up alot and good enough to achieve that power.
PS: i might even have a set of stock LS rods and CTR pistons I can sell for cheap just pm me privately...go with the 94+ LS intake manifold or if you can find the Blox for cheap.
Obviously you can go LSV and get good power too...either way building up with higher compression pistons will give great results...if you're out of fund and cant get a VTEC head put the CRV had for now until you can afford it thats all.
I have a b18b1 with the p8r head. Still feels like an ls. I think I need high comp pistons to feel a difference. I/h/e bigger injectors with skunk2 manifold. Maybe after its dyno tuned it'll feel stronger
b20ek
Aug 30, 2004 06:15 AM
