h22a1 swap onto f22a1 block
Old Sep 7, 2014 | 03:44 PM
TheRookie74's Avatar
Default h22a1 swap onto f22a1 block
What all will I need when swapping from the f22a1 head over to the h22a1 head. keep in mind this is a dirt oval car. nothing for the highway,. I know obviously a head-intake-header... was wondering about if my ecu-engine management system will work off my f series motor... thanks in advance.... was considering a K-SERIES swap but went against that obviously after reading up on it.... thanks guys
Old Sep 7, 2014 | 03:48 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: h22a1 swap onto f22a1 block
Top of the page in the FAQ there is the swap writeup of using an H22 head on an F block.
Old Sep 7, 2014 | 03:59 PM
No their isn't a f22a1 over to a h22a1 head swap on there...
Old Sep 7, 2014 | 04:50 PM
MAD_MIKE's Avatar
MM Gruppe B
There are three swap writeups.
F22B1 head on F22A1
H22A head on F22B1
H22A head on F23A1
If you can make a VTEC head work on an A1 you can make a VTEC head work on a A1.
Old Sep 7, 2014 | 09:59 PM
holmesnmanny's Avatar
you can do a search for a g22 as well ... lots of threads on this
biggnubbs
Nov 2, 2005 09:38 AM
preluderider
Sep 14, 2005 10:14 AM
ctrep3
May 24, 2005 08:15 PM
as i lay dying
Apr 21, 2004 05:48 PM
phthalo
Apr 20, 2004 07:41 PM
