P28 Jumper harness obd2a/obd1 issue 96 civic ek
I have a 96 civic ek hatch that used to be automatic and hot converted before I got it. The ecu has been giving me problems so I got a p28 to swap it when I pulled the automatic ecu out, the fourth connector wasn't there now I can't connect the p28 in cause the fourth connector is needed for the jumper harness. Please help !
What motor is in the car?
Is the p28 chipped?
Your civic is ODB2 car the p28 is ODB1 so to run it in your car your going to need a ODB2 to ODB1 ecu conversion harness. Check the classifieds I think I seen one there not to long ago.
Is the p28 chipped?
I got the obd2a jumper harness with a d16y7 motor in there. It used to be automatic but got converted to a 5spd .the ecu for an automatic civic is in there now and I'm trying to hook up the p28
Oooooooo op, the last connection is for the auto plug. Dnt worry about that. I did my auto to manual swap and i had to leave the last plug.
jorgejam2001
Sep 25, 2009 08:47 AM
essex
Apr 15, 2002 07:37 AM
