PR4 ecu wire color code
I'm trying to locate the VSS wire from my ECU. Info that I got from the internet says its pin B16. I didnt count the number of pins but looking at the plugs on the ECU, they were numbered accordingly. I figured the B plug is the one in the middle. However, the B16 plug I found is a white wire and the VSS wire that I'm looking for is suppose to be yellow/red. Anyone have a PR4 ecu pinout location w/wire color code? Or should I just splice the vss lead wire to any yellow/red wire from the ecu plug?
dingusjt
Nov 13, 2003 10:18 AM
