MA 1999 Civic Hatchback CX swap
For sale is my 1999 Honda Civic Cx K-Swap Hatch. It has a clean title, with roughly 120,000 miles. The motor itself currently has bout 8xxx miles since it was built. A ton of money was spent on parts and labor.
The car was dyno at 251 hp to the wheels.
I´m asking for $8,000 OBO
http://www.k20a.org/forum/showthread.php?t=102552
Motor:
k24a1 Bottom end (Block was machined and balanced)
87.5 Bore 12.5.1 Supertech pistons
2006 k24a2 top end. (Head was cleaned and machined; Originally 26,000 miles before machining)
2008 Civic si Transmission (Rebuilt)
Brian Crower H beam rods
TSX 99mm Crank
TSX 36mm RBB head
06-08 TSX Cams
50 Degree VTC gear
RBC IM
62.5mm RSX TB
RDX 410cc Injectors
DTR/SSSR 4/2/1 Headers
T1R 2.5 exhaust
Aeromotive Fuel Pressure regulator
PRB Kpro
Tucked wiring harness
Hybrid Racing full size radiator
Hasport Mounts EKK2
Suspension/Brakes:
GSR subframe and Power Steering Rack (Subrame and all suspension parts were powder coated;Steering rack was rebuilt)
LS Front sway bar and endlinks
CTR rear sway bar
Hardrace 24pc bushings kit (All suspention bushings were replaced)
Hardrace front and rear camber kit
s2000 front calipers and rotors
rsx/ep3 rear calipers and rotors
Hawk pads front and rear
ITR brake booster
Civic Si Brake prop valve
Interior:
OEM CTR Carpet
OEM Si gauge
Integra LS front and rear seats
Exterior:
Replica CTR front and rear lip
Replica CTR headlights
Replica Spoon rear spoiler
Rota Wheels
Motor:
TSX 99mm Crank
TSX 36mm RBB head
06-08 TSX Cams
50 Degree VTC gear
RBC IM
62.5mm RSX TB
RDX 410cc Injectors
T1R 2.5 exhaust
PRB Kpro
Hasport Mounts EKK2
Suspension/Brakes:
CTR rear sway bar
ITR brake booster
Interior:
OEM CTR Carpet
OEM Si gauge
Exterior:
Rota Wheels
Saw this car on CL not too long ago, knew it was a quality build even with the vague description. Good luck with sale, if I hadn't purchased my hatch I would definitely be interested in this.
