Will Honda power steering fluid stop leaks?
Old Sep 5, 2014 | 04:29 AM
h4mza's Avatar
Default Will Honda power steering fluid stop leaks?
My power steering fluid is leaking and the level is very low and needs topping up. I was told to use only Honda branded power steering fluid as others will cause damage. I've seen a few third party brands at local car parts store which say Stop Leaks on their title but cannot find Honda branded anywhere other than eBay and on the description part, it doesn't say anything whether it will stop leaks. So I'm confused now, does anyone know if the Honda power steering fluid actually stop leaks?
Old Sep 5, 2014 | 05:06 AM
egsleepercivic's Avatar
Default Re: Will Honda power steering fluid stop leaks?
I doubt it unless the leaks were caused by using the wrong fluid
at pretty much any auto parts store there are 2 kinds of Powersteering fluid
fluid for hondas and fluid for everything else,
the stuff for hondas acuras will say it on the bottle, unless you go to the dealer it will not be made by Honda
Old Sep 5, 2014 | 09:55 AM
tony_2018's Avatar
Fish Twig
No it does not stop leaks, Honda rack and pinions use specifically Honda fluid unless otherwise noted by specific yr/make/models.
Old Sep 5, 2014 | 10:22 AM
NotARaCist's Avatar
I never narc'd on nobody!
No, Honda fluid doesn't have stop leak in it. Stop leak is a horrible creation, and will destroy your rack. Fix the leak.
Old Sep 6, 2014 | 03:25 PM
firehawk618's Avatar
There is NO fluid that will stop leaks in anything. If by some miracle the wrong fluid caused a part to leak that part is now damaged and needs repaired.
Old Sep 6, 2014 | 06:03 PM
pdidnotkno's Avatar
if you use any kind of stop leak in anythig the only thing are doing is swelling up your seals, when In time it will start to leak worse than ever
W95civicEXcoupe
17
Apr 14, 2015 06:11 AM
jvue
May 21, 2010 12:17 PM
Brian-Brian
Oct 25, 2003 02:29 AM
jetli
Oct 31, 2001 12:11 PM
