Fuel cut off after cranking
Old Sep 4, 2014 | 12:40 PM
karmunkey's Avatar
Default Fuel cut off after cranking
Hello, my problem that I can't get the motor to stay running. Now the background on this is. I got the car which is a 1990 integra ls but I had a b16a swapped in. Its got a knocking rod so I swapped a b18b1 from a 1995 integra. The motor codes on the head says it's a 94. I got the mechanical part of everything done. Switched the injectors from the b16 over to the b18. And repinned the distributor for obd0. I'm running a pr4 ecu. Guy I bought it from had it in the car from the originally swap. Just swapped out the main relay with a new one. It will crank and it wants to start but them dies. What am I missing???? Getting all 3 clicks from the main relay on the old and new relay. Can hear the fuel pump priming(I think). Checked the plugs, wires, dizzy. And I'm getting spark on each cylinder. They guy I bought it from had the ecu chipped that I took out. I'm doing circles over here and can't figure out what's wrong. I also tried both fuel rails. And no luck. Car use to start before I did the swap. And did i mention this is my first swap. Did plenty of research before. And my daily drive is an ek swapped with a b18b1. Help!
Old Sep 4, 2014 | 11:28 PM
holmesnmanny's Avatar
Default Re: Fuel cut off after cranking
This sounds like a crank sensor or cylinder sensor issue. Check over all of your wiring again.
Old Sep 6, 2014 | 12:10 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
is it throwing any codes? either of these issues would. obd0 has a light on the actual ecu, rather than using the CEL on the dash.
and you can hear the fuel pump prime like normal? does it sound any different than it used to?
james myers
Engine Management and Tuning
Jan 19, 2017 12:08 PM
95turboeg
11
Jun 13, 2013 03:51 PM
njteggy
Oct 5, 2011 07:21 PM
a1320honda
Nov 26, 2009 07:46 PM
NewIntegraKid
Sep 3, 2002 10:09 AM
