CA FS 96 ek hatch full sports front wheel drive/outlaw class drag shellshell
Old Sep 3, 2014 | 06:54 PM
aser1z's Avatar
Default FS 96 ek hatch full sports front wheel drive/outlaw class drag shellshell
I have for sale a 1996 clean titled drag Honda Civic hatchback SHELL. It is built for sports front wheel drive and outlaw class. Yes, just the shell but will come with everything in the pics except the front mount intercooler and blow off valve. All you need is to drop your swap in set up your own fuel system+battery and have fun(I can’t find the pink or registration at the moment since I have moved 3 times this past year and might have misplaced it but will have bill of sale from me).
I'm located in northern San Diego
ASKING $5,500
Engine bay
Shaved and painted
Harness and brake lines are tucked
Solid bseries mounts with welded and reinforced plates
Fuel sump
NO ENGINE
Exterior
Exospeed front end
Reinforced front bumper brackets with quick bumper release tabs
Stock 99 ek hood
Side mirror deletes
Driver window safety net
CCC racing spoiler
99 ek lights
Golden eagle rear bumper diffuser
Parachute
Carbon fiber trunk
Interior
Kirky racing seat
Si cluster
Boost/oil pressure/ water temp/ aem air fuel gauge
Momo extended hub with momo steering wheel
Whitfield custom roll cage(parachute handle release built on to the cage)
Battery relocated on passenger side and it’s a 16V set up so no need for an alternator just a bigger battery)
Custom ecu mounting plate located under the glove box
Suspension
99 si front and rear disc conversion
Wilwood brake booster delete
Extended studs and lugnuts
Skunk2 first gen suspension non adjustable but set up for drag racing
Skunk 2 camber kit front and rear
Steel braided brake lines
Front traction bar
Rear skunk2 lower control arms
wheels+slicks and skinnies+tires are included.
I'm sure I forgot parts to list.
Old Sep 4, 2014 | 08:42 AM
aser1z's Avatar
Default Re: FS 96 ek hatch full sports front wheel drive/outlaw class drag shellshell
BUMP
Old Sep 10, 2014 | 02:43 PM
aser1z's Avatar
ttt
Old Sep 10, 2014 | 10:08 PM
aser1z's Avatar
TTT
Old Sep 10, 2014 | 11:17 PM
jthm's Avatar
200.00, pm me if interested
Old Sep 15, 2014 | 09:42 PM
aser1z's Avatar
bump
aser1z
Sep 15, 2014 09:46 PM
dylthomas
Jun 10, 2014 09:41 PM
paul_573
Jun 24, 2003 02:27 PM
paul_573
Jun 22, 2003 09:22 PM
