Will a JDM Sir sterring wheel fit?
Old Oct 31, 2002 | 08:49 PM
EndlEEsss's Avatar
Default Will a JDM Sir sterring wheel fit?
Does anyone know if this will fit on a 5g accord?
and how about the cruise control ?
Its from a 96 Sir.
thanks
[Modified by TweakMeUp, 9:50 PM 10/31/2002]
Old Oct 31, 2002 | 09:22 PM
Brandon's Avatar
Life is Suffering
Default Re: Will a JDM Sir sterring wheel fit? (TweakMeUp)
It doesn't look like it is an airbag wheel, so I don't think it'd work.
Old Oct 31, 2002 | 09:27 PM
GimpyAccord's Avatar
Default Re: Will a JDM Sir sterring wheel fit? (Brandon)
heh, it looks like a leather wrapped 4th/3rd gen wheel.
Old Oct 31, 2002 | 11:11 PM
Regulator's Avatar
so does that mean that an aftermarket steering wheel won't work either?
Old Oct 31, 2002 | 11:32 PM
FastechAccord's Avatar
Default Re: Will a JDM Sir sterring wheel fit? (95vtecaccord)
YES!! It should work. It doesnt matter if it has an airbag or not. There is a clip inside the steering wheel hub that you put the air bag connector in when not in use.
Old Oct 31, 2002 | 11:42 PM
JDM_CD7's Avatar
Default Re: Will a JDM Sir sterring wheel fit? (EvoAccord)
I'm with Gimpy...... looks like a 4th gen leather wrapped to me
Old Nov 1, 2002 | 02:50 AM
WhoNeedsVtec's Avatar
Default Re: Will a JDM Sir sterring wheel fit? (JDM_CB7)
im with the gimp also
Old Nov 1, 2002 | 04:59 AM
Stew Pidasso's Avatar
Default Re: Will a JDM Sir sterring wheel fit? (GimpyAccord)
That's exactly what it is...
Old Nov 1, 2002 | 07:43 AM
EndlEEsss's Avatar
how about the cruise control button?
Old Nov 1, 2002 | 09:31 AM
juicedh22's Avatar
actually, I dont know if it will directly bolt in because of the SRS system....
Old Nov 1, 2002 | 09:48 AM
Default Re: Will a JDM Sir sterring wheel fit? (juicedh22)
go lookup aftermarket steering wheel adapters. if 4th and 5th gens use the same momo part no. chances are it will fit.
Old Nov 1, 2002 | 10:08 AM
Regulator's Avatar
well then it won't work, i have a 4th gen momo adapter, and the part number is different from the 5th gen, which is what i need
Old Nov 1, 2002 | 11:12 AM
EndlEEsss's Avatar
is that the final answer?
thanks guys
k_lude
Jul 7, 2007 12:00 AM
DC2-JRSC'd
Oct 24, 2006 03:21 PM
fast_honda
Aug 31, 2006 07:25 AM
hp92lude
Aug 25, 2006 07:18 AM
GtechPro
Apr 3, 2006 12:38 PM
