Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Alignment / Suspension woes
Old Oct 31, 2002 | 08:39 PM
stumpyf4's Avatar
Default Alignment / Suspension woes
Firstly I bought my teg in April from an Acura dealer. It was stock and it needed new tires so I talked the dealer into selling it with the worn tires and I would replace. I brought it back with the new tires and had an alignment done. something was out of wack and they replaced the upper control arm and wheel bearing on the front right. All was well, or so I though.
In september I installed some Koni's and Prokits. With every settled I had it aligned at another Acura dealer... closer to work. It appears things are still amiss with the front right. Camber is at -2.4deg and caster is at -0.7 (both way out of spec.)... the front left is -0.9deg camber and +1.2deg (both in spec.) Now with the suspension lowered I doubt that the original dealer will fix the problem... but my contention is that it was not fixed in the first place. They threw parts at it and it still was messed up.
Any thoughts/advice?
Old Nov 1, 2002 | 01:18 AM
RacerMike's Avatar
Default Re: Alignment / Suspension woes (stumpyf4)
Replace OEM parts, return to original dealer. You may want to get another alignment done with the OEM parts from a 3rd shop first though.
Mike
[Modified by RacerMike, 5:18 AM 11/1/2002]
mickey513
Suspension & Brakes
Sep 13, 2013 06:05 PM
djtsmith007
Apr 15, 2009 08:51 PM
briver2006
May 7, 2008 08:28 AM
latrungkiet
Jul 5, 2005 03:33 PM
Type R1
Apr 24, 2002 05:14 PM
