How do I upgrade my injectors.
Old Sep 2, 2014 | 09:37 AM
JonathanCD5's Avatar
Default How do I upgrade my injectors.
I have a 94 accord with the F22 engine. The engine is bone stock and apparently uses 240cc injectors. I want to upgrade to a bigger size injector. What would be a good size that I can upgrade to without damaging the engine. And what mods do I have to do (if any) before I upgrade my injectors. Thanks and have a nice day bros.
Old Sep 2, 2014 | 10:12 AM
AznBlueBoy's Avatar
Default Re: How do I upgrade my injectors.
are you the same guy that asked this on the facebook page?
you don't need to upgrade injectors. It will do nothing for you on your bone stock f22 and will even cost more then your engine is worth.
Old Sep 2, 2014 | 10:15 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Why?
Old Sep 2, 2014 | 11:29 AM
hondamark35's Avatar
when the dyno *man* says you could make more power if only you could add more fuel. (160hp being the estimated limit for your stock injectors, probably)
Old Sep 2, 2014 | 11:39 AM
2LEM1's Avatar
I like to party
Community Builder
A bone stock F22 needs more than a 240cc injector?
... and a dyno says he needs more fuel at 160hp?
Huh?
Also did not know that adding fuel added power. Neat.
Old Sep 2, 2014 | 03:45 PM
what i'm suggesting is that he needs to decide to upgrade injectors when it becomes the limiting factor in creating more power. a tuner trying for more power during a dyno session, but finding things leaning out may suggest larger injectors.
the 160 is an estimate based on the online injector calculators. Adding fuel flow capacity adds power potential given adequate air can also be added. there are some caveats but that's the gist of it.
Old Sep 2, 2014 | 04:19 PM
F22Master's Avatar
Stock 240cc injectors are good until ~200whp. The only benefit you would see by changing injectors is if you switched to one using newer technology and better spray patterns (ID injectors, RDX injectors, etc.).
Old Sep 2, 2014 | 04:44 PM
spAdam's Avatar
Loved
Community Favorite
More like 200 flywheel HP, and that's with a bump in pressure.
Old Sep 2, 2014 | 06:32 PM
2LEM1's Avatar
I like to party
Community Builder
^ Agreed, I hit 175whp on stock 240s and a bump in pressure. This was a VERY stingy dyno, but somewhere in that range, yeah.
Enough to run a 'bone stock' F22 I'd think.
Old Sep 2, 2014 | 08:57 PM
FlewByU352's Avatar
This. I was hitting like 97% injector duty cycle on the 240cc, before upgrading injectors. More or less an open hole that you're trying to force a fluid out of, and the solenoid (injector) getting extremely hot trying to control such events.
I would recommend to anyone now days even with a bolt on setup to at the very least use RDX injectors. Plenty of fuel available and the spray pattern is worlds ahead of the old 240cc injectors. There is power in atomization... and I know from experience dudeeeee! lol
Old Sep 2, 2014 | 09:01 PM
EsotericImage's Avatar
Retired Moderator
Either the dyno guy sells tuning stuff and trying to get in your pocket or he has no clue wtf hes talking about.
Old Sep 3, 2014 | 04:24 AM
No I'm not and thanks
Old Sep 3, 2014 | 04:25 AM
Why?
Because I plan on making more hp in the future and I've heard that bigger injectors is gunna be a must. But I'm asking here because idk if I was told right.
Old Sep 3, 2014 | 04:28 AM
Nah I'm seriously asking I'm just not sure at all I'm very new to the tuning scene that's why I'm asking here. But nvm someone already answered the question
Old Sep 3, 2014 | 05:15 AM
spAdam's Avatar
Loved
Community Favorite
You'll need them later then. If you don't have any sort of tunable engine management right now then injectors are of no use to you... None of them are plug and play.
jceltalentoso
K Series
Mar 13, 2014 03:30 PM
motopete
Nov 4, 2011 09:11 PM
ben222
Aug 27, 2007 11:04 PM
mafay2
Nov 12, 2004 08:24 AM
Excelerate
Jun 24, 2003 12:40 PM
