2002 Accord SE Spoiler removal
Old Sep 1, 2014 | 06:59 PM
conflictserum's Avatar
Default 2002 Accord SE Spoiler removal
I've decided I want the spoiler off the car. there are 2 screws from the trunk lid into the spoiler.
What viable/reliable options are there for sealing the holes left by the screws?
I'm in Illinois so we get a fair amount of snow as well - if that makes a difference.
(There is a 3rd brake light under the rear window as well so I'm not worried about the legality of removing the spoiler with it's brake light).
This is a 2002 Honda Accord SE
Old Sep 1, 2014 | 09:46 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2002 Accord SE Spoiler removal
If you can find some domed 'lug plugs' and then some touch up paint to match your cars color. Use a bit of seam sealer to make them leak free.
Hardware store may have something similar.
Old Sep 2, 2014 | 04:28 AM
Fitz Williams's Avatar
10 Year Member
You could sell the spoiler and buy another trunk lid from a pick-and-pull. You might even find one the same color and in good shape. Most of their cars are hit in the front.
Old Sep 2, 2014 | 01:58 PM
MAD_MIKE's Avatar
MM Gruppe B
Pick N Pull around here has a nice unique way of opening the trunks, usually with a crow bar.
Old Sep 2, 2014 | 10:37 PM
Not a terrible idea. Would a 2001 trunk lid work? I know they changed a bit of the styling on these Accords after 2000, not sure if the trunk is the same.
Old Sep 3, 2014 | 04:08 AM
10 Year Member
Yeah, here too. Last weekend I saw a very nice CL trunk that would have been perfect if they had not used a crow bar on it. Luckily most Accords are not opened that way. I bought a spare trunk in my body color to use just in case I got tired of the spoiler. So far that hasn't happened.
One way to tell if the trunk will fit is to do a swap at the pick and pull. Before you buy it. If it works, good. If it doesn't then someone else has less work to do when they want a trunk lid.
Old Sep 6, 2014 | 12:40 AM
So it's fairly easy to do then?
Mr.EMII
Honda Civic (2001 - 2005)
Mar 10, 2011 04:10 PM
paulab
Feb 2, 2006 01:52 PM
mr_mbuna
Nov 1, 2002 09:16 AM
