Honda CR-V & Element 2WD & 4WD Element & CR-V
Accord coilovers
Old Sep 1, 2014 | 06:02 PM
jayjazmin's Avatar
Default Accord coilovers
I know this has been mentioned plenty of times before but a lot of threads I see are just people saying don't do it or being negative about it. Pretty much just want to know which year coilover sleeves will work on my 99 crv . I have kyb gr2 struts in as well. Don't want to replace them so just wanting to know if there will be any complications to look out for if I were to just put on coilover sleeves. Thanks guys
Old Sep 1, 2014 | 06:21 PM
blackskunk2si's Avatar
Default Re: Accord coilovers
i dont see the big problem with running them, been doing it for 5+ years. mine are 94-97 ones and it rides ok. im sure it could ride better but cant ask for more considering what i paid for them. im running civic struts up front and stock crv ones in the rear. with better struts im sure it would ride better.
Old Sep 1, 2014 | 06:26 PM
jayjazmin's Avatar
What year civic struts did you use?
Old Sep 2, 2014 | 06:52 AM
ek front struts...96-00
Old Sep 2, 2014 | 09:41 AM
jayjazmin's Avatar
Would my front struts not work? Or is the ride height just going to be off
Old Sep 2, 2014 | 12:34 PM
my stock crv struts would bottom out when I lowered it as far as I wanted. the ek struts have a shorter body and lower strut mount so it lowers the coilover mount and gives has more stroke before bottoming out. if you did some extended tophats it would do the same thing
Old Sep 2, 2014 | 07:30 PM
jayjazmin's Avatar
I really do want to keep my gr2s.. How much did you drop it before u had issues bottoming out.. I'm looking to try and get an inch gap between fender n wheel.. Is this possible with the coilover sleeves n my gr2?
Old Sep 3, 2014 | 08:18 AM
I guess it would depend on tire size as well. heres when I first lowered it many moons ago with stock crv struts on 225/45/r17s with an inch or so of gap and it rode ok. bottomed out more than I would have liked but I figured it was old struts plus overly lowered vehicle.
heres current (like just stepped outside work and took pics) with civic struts on 205/40/r17s with about the same gap, maybe alittle less. its lowered more to compensate the smaller tires but has more travel than before. the back still bottoms out so extended top hats are in the super near future and then the whole car is getting lowered to no fender gap.
Old Sep 3, 2014 | 07:12 PM
jayjazmin's Avatar
Well here's my car.. Planning on keeping these stocks for awhile. Hopefully there won't be a problem if I used just the accord sleeves with my shocks. But that drop is perfect. Looks even better currently. But i just don't want the car to be too slammed since I'm usually loading the car up with kids n groceries -_-
Old Sep 4, 2014 | 09:28 AM
if youre just killing the fender gap that you have now on those current wheels/tires then I think youll be ok
Old Sep 5, 2014 | 08:39 AM
jayjazmin's Avatar
Awesome thanks for all the help bro.
Old Sep 5, 2014 | 06:32 PM
youre welcome dude
Old Sep 6, 2014 | 10:01 PM
tony_2018's Avatar
Fish Twig
What are you using for the rear struts? The rear lower control arms are not the same as the civics. The rear struts are almost like the ITR's.
Old Sep 7, 2014 | 06:49 AM
im running stock crv struts with extended tophats in the rear
Old Sep 12, 2014 | 10:49 AM
jayjazmin's Avatar
A friend of mine has some oem 96-00 civic springs and shocks. Will this fit my ride? Problems?
Old Sep 12, 2014 | 10:25 PM
EsotericImage's Avatar
Retired Moderator
No
Liberty.R
Suspension & Brakes
May 18, 2012 01:34 PM
slotec
Suspension & Brakes
11
Oct 3, 2005 08:26 PM
danielbendorf
Suspension & Brakes
Mar 16, 2005 02:26 PM
willy.wonka
Nov 4, 2003 05:27 AM
B18Ccivic
Feb 26, 2003 08:01 PM
