91 Accord Wagon Manual Transmission ID
Old Aug 31, 2014 | 12:22 PM
Crucialambition's Avatar
Default 91 Accord Wagon Manual Transmission ID
I've had this wagon for a couple years now and the inner and outer drive shaft seals finally are bad and I want to replace them, I just don't have a clue where my transmission came from.
It was originally an Auto, but the previous owners said they turned it into a 5 speed. Me of course never asked what the tranny came out of. Since then I'veost contact with the previous owner and am now on my own to figure it out.
I don't know if this has anything to do with it but the casing is stamped YSK-1 and I also posted a picture of the tag on the tranny (H2U5-5019872). I've tried looking it up on google, but no luck pulling anything up. Any help is appreciated considering I'm losing tranny fluid something fierce.
Old Aug 31, 2014 | 12:44 PM
holmesnmanny's Avatar
https://honda-tech.com/forums/showth...441&styleid=18
93 accord however most f and h series all use the same axle seals anyhow
Old Aug 31, 2014 | 02:09 PM
Default Re: 91 Accord Wagon Manual Transmission ID
Appreciate that highly. Onward to the auto part store.
Old Sep 1, 2014 | 03:44 PM
It's best to use Honda OEM seals. If you do try to use an aftermarket, make sure to grease up fairly good the inner lip where the axle goes through. Honda OEM seals come pregreased so it's never needed on those. If you dry run an aftermarket seal it could tear it before it breaks in causing it to leak.
CivicNut
Nov 14, 2005 10:57 PM
slow_yota
Jul 3, 2004 05:55 PM
hacman
Jun 16, 2004 04:03 PM
wyldbil
Jun 2, 2004 06:35 PM
Tanmt
Aug 29, 2002 09:32 AM
