Evergreen high psi Oil pump
Old Aug 31, 2014 | 02:23 AM
aavtec's Avatar
Default Evergreen high psi Oil pump
Okay so I just picked up a b18c1 short block and am getting ready to rebuild it. I was doing some late night research when I can across this oil pump
Amazon.com: Evergreen OP4008HP High Performance Oil Pump 96-01 Honda Civic Acura Integra 1.6 1.8 DOHC B16A2 B18B1 B18C1 B18C5 B20B4 B20Z2: Automotive Amazon.com: Evergreen OP4008HP High Performance Oil Pump 96-01 Honda Civic Acura Integra 1.6 1.8 DOHC B16A2 B18B1 B18C1 B18C5 B20B4 B20Z2: Automotive
My question is, has anyone used this oil pump before or have any input on it or the manufacture ( Evergreen I believe ). The posting states its a high performance high psi. oil pump, But there are no details in the description explaining why it is high performance. Any input is greatly appreciated.
Old Aug 31, 2014 | 08:54 AM
PSI GUY's Avatar
Default Re: Evergreen high psi Oil pump
Probably similar to the TOGA pumps that were out years ago, just junk. Pro-Drive or now Circuit worx oil pump.....if you can find one or just OEM honda with a good damper. And I didn't mean TODA for the pump, those are good, the TOGA ones were a complete oil pump assembly with cover that was supposed to be a high volume unit, none of them lasted.
Old Aug 31, 2014 | 04:17 PM
90efhatch's Avatar
I would not trust that oil pump. Isnt evergreen the company that sells crappy gasket kits on ebay?
I would just get a Honda pump.
Old Aug 31, 2014 | 04:33 PM
halfakneegrow's Avatar
i agree ^ if you want a higher volume pump buy an oem and have 4 piston port it out or buy the toda gear kit.
Old Sep 1, 2014 | 05:37 AM
m4xwellmurd3r's Avatar
The toda gear kit does NOTHING for pump volume or pressure output. They are simply oem spec gears made out of billet steel vs sintered steel for increased durability
Serdar
Oct 12, 2005 12:10 AM
