Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 Civic Si Squeaky/Popping Clutch
Old Aug 29, 2014 | 09:49 AM
ckempa93's Avatar
Default 06 Civic Si Squeaky/Popping Clutch
Hey guys! I have been lurking these forums for awhile now and thought I would finally make a post about a nagging issue I've had with my 06 Civic Si. I've posted this over at the 8thcivic forums, and had no luck.
Before all of this, my clutch was perfect, no noise at all. I changed the Clutch Master Cylinder to the one from Hybrid Racing(http://www.hybrid-racing.com/store/8...r-upgrade.html), to fix my 2nd gear grind issue and now it shifts great, but it's squeaking like a ****. And popping. Its all I listen to when I drive. Heres a vid:
The sound is coming from the clutch. Again i'm using the Hybrid Racing CMC adjusted by my local shop. Note the consistent squeak when depressing the pedal, and the pop that generally occurs towards the bottom of the pedal as I'm releasing it. It can sometimes pop up to 4 times during a gear change. Other threads I've read on this issue are people using the stock CMC, and getting it replaced fixing it, but mine is already replaced and it's doing it. Please help!
Thanks
-Chris
EDIT: I guess you can't embed youtube videos on this forum?
Old Aug 29, 2014 | 12:08 PM
97emsedan's Avatar
Default Re: 06 Civic Si Squeaky/Popping Clutch
The squeaking is cavitation, there is air in the clutch hydraulics. That popping noise could be the result of a lack of fluid, such as if the piston has compressed the air in the lines and that pop results.
Bleed and fill your clutch hydraulics and see if the noise goes away.
Old Aug 29, 2014 | 10:53 PM
DaveSi677's Avatar
Old Aug 29, 2014 | 11:16 PM
ckempa93's Avatar
So just drain the clutch fluid and refill and bleed it. I can do that over the weekend. I'll report back with the results! Also, I've read that putting lithium grease in the hole could also alleviate the noise? Seen in this thread.
http://www.8thcivic.com/forums/clutc...ng-clutch.html
Thanks guys, I'll report back
-Chris
Old Aug 30, 2014 | 03:18 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
No....there's probably not air in the lines is the clutch is disengaging properly. Air in lines doesn't make creaking or popping noises.
Op...first check that your pedal bracket isnt cracked.
Then try greasing the pivots in your master cylinder and slave cylinder. On the master cyl, there is a rod that runs to the clutch pedal. Grease that rod where it goes into the master cylinder body.
Then unbolt the slave cyl (don't undo the lines!). Clean the pivot ball where the slave meets the clutch fork. Clean the clutch fork socket also. You may have a "nipple" forming on the slave cylinder pivot ball. You can file/grind that smooth. Grease up the socket in the clutch fork. Grease the pivot ball.
Use Honda HT urea grease or another good bearing grease. Don't use anti sieze or WD40.
Old Aug 30, 2014 | 09:12 AM
ckempa93's Avatar
I'm going to try the grease thing first also mentioned in this thread
I guess I will have to remove the cmc to do all that stuff...that sucks it took me 3 hours to install the damn thing.
Old Aug 31, 2014 | 11:47 AM
B serious's Avatar
?? Why do you have to remove the CMC to grease it? Look under the dash. It's right there.
Check the pedal bracket for cracks while you're down there.
I'm not sure why everyone has so much trouble replacing CMC's. It shouldn't take more than like 30 mins. Are people doing it without removing the cowl or something insane?
Old Aug 31, 2014 | 05:29 PM
ckempa93's Avatar
Well I sprayed some Lithium Grease into the cylinder and the noise stopped. It was dead silent. 24 hours later, the pop has returned. The squeak is still gone, but I hear one pop right as I release the clutch from the floor... every time
Old Aug 31, 2014 | 06:02 PM
duckmanEG's Avatar
Sexy Cheese Cake
My car does this. So annoying. Using em1 cmc and braided line. Got my setup before the hybrid was available.
Old Sep 1, 2014 | 08:13 AM
97emsedan's Avatar
Did you look at the shift fork at the slave cylinder end? Was it burred as the previous post from B serious? The pivot ball and shift fork interface?
Just thinking it through with you...
Old Sep 1, 2014 | 07:52 PM
B serious's Avatar
So...did you check the bracket for cracks....or....?
Lithium grease doesn't last long. Which is why I suggested honda urea grease.
Old Sep 10, 2014 | 10:44 AM
ckempa93's Avatar
Well after a couple weeks the squeak has returned. I just regreased and the squeak still remains. I can deal with that, it was mostly the poppiing that got on my nerves. That is gone after I re-greased. The bracket has no cracks, and I haven't got around to looking at the slave cylinder. Doing the easy stuff first. I'll check out the Honda grease you were talking about.
Thanks
Chris
NxCmp
Jul 19, 2012 05:12 PM
h23darkprelude
Nov 18, 2009 08:34 PM
miteyjay
Feb 6, 2007 11:14 PM
