Replacing Rear Marker Light and Turn Signal Assembly
Old Aug 27, 2014 | 03:43 PM
HondaKitten's Avatar
Default Replacing Rear Marker Light and Turn Signal Assembly
Hi!
My boss ran into my 91 Honda Civic Wagon RT4WD and cracked the lens on my passenger side rear marker and turn signal assembly. I just got the replacement assembly, but I can't find a diagram anywhere (owner's manual, Chilton's, online) of the fasteners holding it on and how to access them. Anyone have a diagram? Or the ability to explain how to get at it?
I'll go at it with a ratchet tonight and see where that gets me.
Old Aug 27, 2014 | 05:17 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Replacing Rear Marker Light and Turn Signal Assembly
You have to remove the plastic panels. Then disconnect the electrical connectors for the bulbs on the old assembly. The assembly bolts should be held on with nuts (remove the nuts). As the new assembly usually doesn't come with the gasket, re-use the old one to ensure a water-tight seal.
Old Aug 27, 2014 | 06:06 PM
Thank you!
Old Aug 28, 2014 | 12:09 PM
Well damn, any hints or tips about how to strip the interior panels? Everything I've found is for the regular civic, not the wagon. And no diagrams for the rear interior. Grrrr...
HondaKitten
Sep 3, 2014 12:44 PM
eric587
Apr 19, 2012 02:02 PM
D16Z6racing
Jan 18, 2011 08:05 AM
90jdmcrxdude
Aug 5, 2006 07:04 PM
tysf
May 31, 2002 04:40 AM
