94 accord ex- gonna do a swap, which one?
First honda I ever owned and I want to make it a project car. Don't know much about the accords but from research I see you can do an F20b swap, f22 block with the H22 head, just hook up the original engine and boost it heavy?? Also the k20 but far too expensive I was told. Any other ideas or which is the best route?? I will be turbo-ing the hell out of it too so keep that in mind. Thanks for the help and input
I want to make it a sleeper. I'm looking to still run on pump gas. Just a regular looking street car that has a lot of boost and whatever engine swap I Put in. Purpose-a street worthy turbo'd out car.
F20B is 200hp as well.
I probably wouldn't turbo either of those with stock internals.
I'm not going to keep stock internals. I plan on doing the engine swap as well hooking the engine up. I'm buying whichever engine is the best for turboing. Putting the engine in the garage and working on it then putting it in. I'm already looking at suspension for it as well but now I'm just looking into what engine. Thanks for the info already
2171USMC
May 31, 2018 01:40 PM
