94 Honda Accord Timing Marks off, smooth idle?
Old Aug 25, 2014 | 06:40 PM
Ma2kreis's Avatar
Default 94 Honda Accord Timing Marks off, smooth idle?
What im working with is a 94 lx 2dr coupe accord with manual trans. It has a swapped in F22B1 with LX engine harness and LX distro.
During acceleration starting around 2k rpm and up, the car sounds like someones taking the air intake off @ the TB... I've had a previous F22B1 with 233k on it that sounded smooth and even as it went through the RPM range, but this motor sounds like a subaru in the engine bay! Everything is all stock spec. The upper timing cover is missing and I've come to see that when the crank pulley shows #1 TDC, the cam sprocket shows differently, it is off a bit. I know a tooth or 2 off can cause problems, but what gets me is my car idles as smooth as glass. Do you think this engine noise is caused by the misalignment, and be solved by a crank/Cam realignment and valve adjustment? Any wisdom appreciated!
Old Aug 25, 2014 | 08:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 94 Honda Accord Timing Marks off, smooth idle?
If using the B2 harness/ECU the engine will not run correctly and VTEC of the B1 will not be activated. Wrong fuel/timing maps if using a B2 ECU for the B1.
Reset the cam belt timing, and install the correct ECU with the wiring needed to activate VTEC.
If the cam timing is retarded the engine may run smooth, but the power will not be there.
Old Aug 25, 2014 | 08:25 PM
holmesnmanny's Avatar
You definitely need the mechanical timing to be spon on. Like mike said, check to make sure you got the b1 ecu.
Old Aug 25, 2014 | 10:22 PM
Ma2kreis's Avatar
Im assuming its the B2 harness because it has the electrical connectors for the external ign coil for the LX distro, and VTEC solenoid electrical connector is not connected to anything. Im gonna make this a weekend project, is it difficult to replace harnesses? I'll need the harness, distro, and EX ECU, anything else?
Old Aug 25, 2014 | 11:05 PM
ok now i'm lost. What does is the engine block stamp say f22b1 or f22b2 ? Does the valve cover say vtec on it ?
Old Aug 25, 2014 | 11:42 PM
Ma2kreis's Avatar
Its the F22B1, valve cover has VTEC on it. Its the EX motor in the LX chassis.
Old Aug 26, 2014 | 01:07 AM
Nevermind
joebmx
Mar 5, 2009 05:09 PM
crxcess
Jun 13, 2007 09:39 AM
Infinity_Racer
Sep 20, 2004 06:02 PM
PatrickGSR94
Apr 11, 2003 04:21 PM
