yonaka/ hasport?
does anyone have yonaka swap mounts in there EF/crx?
on that note the urethane is not really the best.
so was thinking of buying some hasport replacement urethane.
just emailed them about the size Comment: what size are your Replacement Urethane 70A?
3x5x4
has anyone tried swapping inserts?
http://www.yonaka.com/Honda_Acura_88..._p/ymmm001.htm
http://hasport.com/store/index.php/a.../urethane.html
3x5x4
ok just tried to email yonaka, there email is full. what a lousy company. so i called and the sales associate had no idea what the size of there urethane was even after putting me on hold to talk to a tech.
Why not just buy the Hasport mounts? They have a lifetime warranty on the urethane and will replace it for you if you send the mount in.
Or the innovative steel mounts are budget friendly as well.
Hasport mounts are superior in all aspects.
I have done swaps for 15 years and I have blown up Yonaka, HCP, Place Racing and generic mounts. Never been able to ruin Hasports, and they always fit right every time.
A buddy recently put an h22a into an ek with yonaka mounts, the timing belt end of the engine was so close to the strut tower you could barely slide a piece of paper between, he also broke nipples off the back of the manifold because it would not clear the firewall. I convinced him to let me order him a set of Hasport mounts and we started fresh....it fit right, sat perfect, and worked right from the get go.
Hasport costs the most, and they deliver on every dollar you spend. I will only swap with Hasport mounts or stock mounts, no one else is worth wasting the money on to me.
90civicstdgold
Oct 28, 2010 01:58 AM
