Brakes Issue '98 Civic LX
Old Aug 25, 2014 | 07:27 AM
Tropical Dan's Avatar
Icon6 Brakes Issue '98 Civic LX
Before I did any work the brakes worked fine, except for the telltale sqeak when braking. I just changed the rear brake shoes and the front brake pads with no problem. I pushed the pedal 3-4 times and the pedal felt good. I started the engine and pressed the pedal and it went to the floor. I pressed several more times and and the pressure only increased a bit. I repeated the procedure and noticed the idle slowed. I shut off the engine and pressed the brake pedal, and it felt good, not hard or soft. I started the engine, pressed the pedal and again, no brakes. I'm sure someone has run into this, what's causing the brake pressure to go away and idle to change, only when the engine is running?
Old Aug 25, 2014 | 08:23 AM
00silverdxhatch's Avatar
Default Re: Brakes Issue '98 Civic LX
If the pedal goes to the floor chances are there is air in the brake lines somewhere.
Old Aug 25, 2014 | 10:27 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The idle changes because you are robbing the engine's vaccum using the power brake booster (normal).
The pedal pressure changes because you are compressing the air that you have introduced into the lines somehow. Did you open up any brake hoses or lines?
Old Aug 25, 2014 | 07:42 PM
Thanks. I think bleeding the brakes all around is the next step.
Mecca8383
Sep 27, 2016 09:00 PM
MooreBoost
May 25, 2004 04:50 PM
B2AMMO
Jan 13, 2004 03:59 PM
JCCOOL43
Oct 21, 2003 08:08 PM
