missing map.sens connector/plug
Old Aug 25, 2014 | 12:25 AM
joytjuhhhh's Avatar
Default missing map.sens connector/plug
hi honda guys !
im using a delsol engine loom
and a eg5 esi interieur loom.
and using a map sensor mounted on the firewal
before i used the same engine loom and map sensor in a del sol and had a plug for the map
but now he isnt there anymore !
the tps and evap connectors are at there good place
i didnt cut anything and there is no alcohol in my blood en if cleaned my glasses
im thinking that the plug in de sol came straigt from the ecu
and at some site a read that the map plug was wired into the ABS loom
and another site says the plug was wired in the interieurloom
(But thats incorect i think)
Should i wire the map directly from the ecu
cut the wires and extend the wire to the map sensor tru the firewall
or schould i extend the cables from the schokertower plug ?
cut and extend the wires
thnx in advandce
Old Aug 26, 2014 | 09:32 AM
joytjuhhhh's Avatar
Default Re: missing map.sens connector/plug
Nobody who have also been at this point ?
Greetz
XxRoCkMaNxNEOxX
Sep 15, 2013 01:43 PM
CRXFREEK9000
Feb 24, 2011 06:41 AM
hatchinprogress
Dec 30, 2005 02:05 PM
soulrider4ever
Oct 27, 2005 04:12 AM
JDMlyfestyle
Oct 17, 2004 05:27 PM
