Civic Starting Issues
Old Aug 24, 2014 | 05:42 PM
jjb193's Avatar
Default Civic Starting Issues
I have a 1999 Honda Civic EX I bought brand new and love but I have two problems.
Problem 1: For the past few years, especially in the heat and humidity, the car won't start on the first try. I will turn the key and nothing happens. There is not cranking sound and not warning lights. After a few tries the car will eventually start. I had the started replaced a few years ago and this seemed to help but the the problem came back. A friend suggested I try starting the car in neutral when this issues happens and that seems to work.
Problem 2: I was driving home from work in February when the car just died. It turns out the ignition coil had to be replaced. The part was replaced then the 'check engine' light came on/ The code indicated I needed a new catalytic converter. My wife's coworker's husband is a mechanic and said as long as the car is driving fine there isn't an issue but every time the code is cleared it comes back again. Should I replace the catalytic converter?
Old Aug 24, 2014 | 06:09 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Civic Starting Issues
When you turn the key and nothing happens, does the CEL come on for ~3 seconds, then turn back off? Can you hear the fuel pump priming?
What EXACTLY is the CEL code?
Old Aug 25, 2014 | 09:26 AM
keith howland's Avatar
i have honda civic 1.6es,injectors are not opening,squirt gas down air intake it runs.for few seconds,main relay,fuses plugs/sockets checked ok.wher do i go from here?PLEASE HELP getting to end of my tether!! Hope this is correct procedure if not , sorry.
Last edited by keith howland; Aug 25, 2014 at 09:29 AM. Reason: might be using wrong procedure ,new member first time
Ramsey Attar
Honda Insight & CR-Z Hybrid
Oct 31, 2012 08:01 AM
curvy95honda
Mar 7, 2011 08:42 PM
lilhatch89
Nov 16, 2007 01:15 PM
bust
May 13, 2006 11:58 AM
mattuf64
Honda Civic (2006 - 2015)
Mar 21, 2006 03:58 PM
