92-95 Civic hatch front, passenger side transmission mount/bolt
Old Aug 23, 2014 | 01:59 PM
supadupafast's Avatar
Default 92-95 Civic hatch front, passenger side transmission mount/bolt
Does anyone know if this mount/bolt assembly is needed? It is the mount, bolt and bracket assembly that connects that subframe to the front of the transmission. You can access one of the bolts from inside the wheelwell. I stripped the bolt and couldn't put the bracket back on, but engine still sits fine without it, so I'm not sure if I need it. Please let me know if I need it, then I'll go find one. Thanks.
Old Aug 23, 2014 | 02:33 PM
kentk808's Avatar
Default Re: 92-95 Civic hatch front, passenger side transmission mount/bolt
You're talking about the one on the front of the car, looks like a metal stick with 2 big bushings on each end? There is another one on the passenger side as well right? I know a lot of people who aren't running those. I would say its not necessary for the car to function but it does help with dampening engine movement.
Old Aug 23, 2014 | 02:46 PM
NotARaCist's Avatar
I never narc'd on nobody!
It's called a torque mount. If you have stock mounts, yes, you should definitely have it.
Old Aug 23, 2014 | 04:35 PM
Thanks guys. I'll go look for one just to be safe.
96_coupe
Aug 18, 2012 09:03 AM
Emeraldbomber
32
Jun 10, 2012 09:29 AM
550whpcivic
Sep 19, 2010 03:40 PM
redman223
Aug 4, 2008 07:04 PM
Bob_760
May 17, 2007 10:37 PM
