D15z1 head gasket issues
Old Aug 22, 2014 | 12:46 PM
flozella's Avatar
Default D15z1 head gasket issues
New head gasket but water is drippin down block. I need to know how to go about this problem
Old Aug 22, 2014 | 12:58 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: D15z1 head gasket issues
Did you have the head and block checked for warp?
Old Aug 22, 2014 | 01:11 PM
NotARaCist's Avatar
I never narc'd on nobody!
Where exactly is the coolant dripping from?
Old Aug 22, 2014 | 02:48 PM
slogfilet's Avatar
Definitely check where it is coming from... leaking/cracked/split hoses are a likely culprit.
Was anything else replaced with the head gasket?
Old Aug 22, 2014 | 02:56 PM
Bradshaw's Avatar
yeah definitely start by finding the source. there are a lot of hoses back there with coolant flowing through them that could be the culprit. might have gotten cracked during the head gasket replacement process.
Old Aug 30, 2014 | 07:01 AM
flozella's Avatar
I haven't had it checked yet how do I do it at home? And its leaking from the head gasket down the block
Old Aug 30, 2014 | 02:27 PM
slogfilet's Avatar
Did you do the head gasket yourself? If so, what did you torque the head bolts to?
Old Aug 30, 2014 | 03:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also on this note, was the head sent in to check for warp conditions? No amount of reasonable torque will seal up a warped head.
Old Aug 30, 2014 | 07:20 PM
slogfilet's Avatar
Good point. I was just thinking that maybe it wasn't torqued *enough*.
benphillips
May 4, 2013 07:37 AM
simpletuning
Classic Hondas
11
Oct 8, 2009 03:53 PM
new_climber
12
Jan 13, 2009 09:08 AM
fireman mike2288
Mar 13, 2008 10:35 AM
arielb1
14
Nov 3, 2004 07:14 AM
