Obd1 auto ls swap into into 94 eg 4dr
Old Aug 21, 2014 | 05:05 AM
c1poweredeg24's Avatar
Default Obd1 auto ls swap into into 94 eg 4dr
Has any done this swap ? I kno I kno don't do it go ,convert to 5spd.. But I found a guy on here that didn't whole write up on the tcm into the factory harness. I followed his directions to a T but foursome reason the car doesn't shift still and I have 7extra wires that he didn't mention would be left over.
Old Aug 21, 2014 | 06:07 AM
tony_2018's Avatar
Fish Twig
Default Re: Obd1 auto ls swap into into 94 eg 4dr
point to the thread? What wires is he forgetting?
Edit: found thread, so what wires are you asking. You could've at least listed the wires and what those wires lead to. Have you looked in the service manual for the diagram?
Old Aug 21, 2014 | 09:13 AM
my bad i forgot to put down what wires they were.
1. black /red
2. solid blue
3. 2 green/black
4. green /yellow
5. light green / white
6. yellow /white
7. green/ red
these wires are all on the big plug on the obd1 tcm
but there was also another thing i noticed one of the wires had mentioned wasnt the right color... he was saying to connect a green and black to another green and black on the ecu plug. but when i went to check there was a pink/black wire in that location ? kinda thru me off so i just connected to that pink wire. i dont know if that makes a difference
Old Aug 21, 2014 | 10:20 AM
tony_2018's Avatar
Fish Twig
I suggest you look for the pinouts to both the tcm and ecu. Trace those wires and see what sensor they lead to, check the pinout/diagram and you should be golden. Hondahookup.com for the helms manual.
Old Aug 21, 2014 | 02:24 PM
I downloaded a PDF file for the helms. But I can't find the schematic for the tcm ...
Old Aug 21, 2014 | 05:04 PM
tony_2018's Avatar
Fish Twig
You look in the transmission section?
VWkila
Jan 31, 2005 03:31 AM
JBk24crx
Oct 14, 2003 06:15 AM
bemathew
Oct 28, 2001 01:40 AM
