16's or 17's inch wheels!?!?!?!?!?!?!?!?!?
Old Oct 31, 2002 | 04:59 PM
10K2HVN's Avatar
Default 16's or 17's inch wheels!?!?!?!?!?!?!?!?!?
At first, this problem didnt bother me much, but now its starting to get to me!
-i was gonna get 17's because they look *perfect* on integras and i wasnt thinking much into performance, but went you see all those damn cars on the road-you juust wanna tear them a new one!! 16's look okay too but are lighter, cheeper, and the tires are cheeper too! their only about a pound difference in weight, but the hight side wall on 16's will help in straight launches, but the shorter sidewalls of the 17's will help in cornering!! but those damn 17's look *perfect*...
WHAT TO DO?!? what are/would you guys doing??
-help my indecisive ***...
Old Oct 31, 2002 | 05:07 PM
Dan GSR's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (10K2HVN)
https://honda-tech.com/zerothread?id=317990
Old Oct 31, 2002 | 05:24 PM
rodimus's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (Dan GSR)
one of the new Velox rims that come in 17's weighs 12.5 lbs.
they said they used hot die forging to achieve that...
whatever that is.
Old Oct 31, 2002 | 05:47 PM
10K2HVN's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (EVOL)
haha nice one dan, but those wheels arent the best lookin ones that ive seen, and i bet there not even that light... sorry dude..
and those Velox wheels, there light - i give them that - but their look soo ricey and cheep! if only they had a better designer... thx anyways guys...
Old Oct 31, 2002 | 05:52 PM
ladeevtec's Avatar
To be honest, you're right 17's do look good on the integs, and 16's make it look odd, like something's missing. I say you have to pick one or the other... you wanna turn or you wanna launch? I have 17's on my car right now, but after i put on my camber kit, i can't make extremely fast left turns, especially with a passenger cause it scrubs. This is due to the correction of my negative camber, and the offset of my 17's. So if you pick 17's you might have to roll your fender, depending on how dropped your car is, and if you get a camber kit and also the offset of your rims.
If i could turn time around, i'd reconsider the camber kit, because with negative camber, i could rape left turns etc. But now that i have neutral camber, i don't have to worry about buying expensive low pro tires every 6 months.
Your call! Good luck on the decision.. it's pretty hard
Old Oct 31, 2002 | 06:27 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
16's
Old Oct 31, 2002 | 07:53 PM
ken's Avatar
ken
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (SeaBass)
20s
Old Oct 31, 2002 | 07:58 PM
uNF$@#!'s Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (ken)
24" dubs y0
Old Oct 31, 2002 | 08:05 PM
sa21199's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (Soup ****)
16's...got them and like them
Old Oct 31, 2002 | 10:16 PM
jeebusm3's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (sa21199)
16's fit perfect on tegs. Anything bigger tends to look ricey (with some exceptions) 17's also need a shorter sidewall which means less protection from rim damage and more passenger discomfort. Ah yes, and the car has to put more effort into spinning the 17" because of weight and the extra rotational inertia. 16's all the way.
Old Oct 31, 2002 | 11:58 PM
Volcom's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (gtravsr)
I've got 16's and love them. 17's look too big for the integra in my opinion. I was debating between 15's and 16's but went with the 16's for better looks rather than that extra little performance that I would have gained with 15's
Aaron
Old Nov 1, 2002 | 06:12 AM
spoonee's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (Volcom)
16's all day everyday....
Old Nov 1, 2002 | 06:37 AM
illi Adik's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (spoonee)
yes
Old Nov 1, 2002 | 04:45 PM
mey_xanng's Avatar
16's
but if you have to get 17's make sure they they're atleast light http://www.wheelweights.net
Old Nov 1, 2002 | 05:44 PM
initialR's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (mey_xanng)
i used to want 16s due to wieght until i got 17 gram lights with crappy ventus tire but thats not bad for 1200
Old Nov 2, 2002 | 02:33 PM
Audio28's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (initialR)
I sold my 17's for 16's. I like the look with 45 series tires.
Old Nov 2, 2002 | 02:42 PM
2fstGSR's Avatar
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (Audio28)
I am buying 16's with 215/45/16 tires for my 92 GSR.
If you want to upgrade your brakes in the future with Brembos or any other big brakes you might need at least 17" rims with the correct offset to clear the calipers.
Old Nov 2, 2002 | 03:24 PM
teg's Avatar
teg
Default Re: 16's or 17's inch wheels!?!?!?!?!?!?!?!?!? (1fast92GSR)
17" is the way to go. it fit the teg perfectly. just look for a set that is forge and very light. you get the look, you get the lightness, you get the handling that 16" can not offer.
i happen to have a set of Works wheel from japan for sale. look in my sig. located in socal. pickup if you want to.
-teg
Djole_V
Nov 6, 2007 11:26 AM
Nysh
Sep 10, 2007 01:11 PM
jfingers
Jun 25, 2004 04:01 PM
01-1293
May 8, 2003 05:55 AM
BlazinITR
Feb 15, 2003 08:46 PM
