H23 & F22 Throttle cable bracket
Are the throttle cable brackets interchangeable on these two motors? Or when I'm swapping over to the H23 plenum, do i need the bracket that comes with it? I ask because I cant get proper tension of the throttle cable using the F22 bracket. I didn't receive the throttle cable bracket with the H23 plenum when i purchased it. Thanks for your help.
I've got an F22 bracket on my H23 plenum. it bolts up fine. I "tweaked" the alignment a little just by bending the bracket some. worked alright without needing to do that, but I tend to be nit-picky about these things.
