o2 sensor clip missing help!
Old Aug 19, 2014 | 02:57 PM
Blue_ef23's Avatar
Icon3 New hatch project, need help diagnosing!!
UPDATE
I have a obd1 d15b7 bottom end with a obd0 1.6 non vtec head. Which o2 sensor would i need for this mini me swap?!! theres a $150 difference in o2 sensors so i want to make sure i get the right one.
i have a 88-91 si head with obdo dizzy..
im a newb thanks.
Old Aug 19, 2014 | 03:05 PM
4drEF's Avatar
Keyboard Humorist
Default Re: o2 sensor clip missing help!
What ECU are you running?
If your ECU supports a 4 wire, then that's the best way to go.
The readings will be more consistent since there is a heater element in there.
1 Wire relies on the exhaust gasses to bring it up to operating temperatures.
you can use any form of crimps or connectors to attach the wires.
Using a stock connector would be best in the sense that it will make swapping out O2s and disconnecting easier.
Old Aug 19, 2014 | 03:11 PM
Blue_ef23's Avatar
It has a pm5 in it. I don't want to run any wires to the ecu just a plug to hook these 4 wires too so I can plug up a o2..she's crackling and running rich. Just not sure if I need an obd0 or obd1 plug.
I've always done b18 swaps..I'm still a noobie on this
Old Aug 19, 2014 | 03:15 PM
HondaPartsHero's Avatar
Technical Hero
PM5 uses a 1 wire 02
Blue_ef23's Avatar
can i use a different o2 then the 1 wire one without having to go crazy changing or wiring up things?
I have a spare harness that came with the car with a small square plug with Black red yellow and white wires to it.. lots of missing plugs but this is still intact.
Old Aug 23, 2014 | 02:43 PM
Blue_ef23's Avatar
Bump
updated at the top
jDMJeRk
Oct 3, 2019 08:19 PM
Hondamonster
12
Jun 21, 2007 08:19 PM
Dan-R
Dec 12, 2006 06:03 PM
civtegra_hybrid
Sep 14, 2004 01:15 AM
See Are X
Sep 5, 2002 06:19 PM
