Fuel Injector identification needed please
My car is a stock 1993 DelSol SI with a factory V-tec
Back story... Car has been having emissions issues so to clean the factory injecters, but keep the car running I bought a spare set to swap on. I bought a set of used D16Z6 injectors for my 93 DelSol SI off ebay. Well stupidly, I just got them and sent them directly on to my injector guy to clean and flow match & I should have inspected them first.
Anyway, he (injector cleaner) noticed the electrical connectors are not the same across the injectors. 2 are one style and the other 2 are another.
I know alot of stuff interchanges when folks do v-tech swaps and prehaps the seller just found a v-tec car @ the junkyard and yanked them and did not check either.
My first question... can anyone tell me which ones are for my car and which are the odd ball connectors and what motor they are for?
My guess after some research... ODB1 on the left and OBD2 on the right? Yes / no?
My second question... if the odd ***** (OBD2???) will hook up to my harness without modification to my stock harness?
Question 3... If modification is needed, I would need to track down a conversion harness for the 2 oddballs (OBD2????) to make them connect. I see tons of OBD@ harness to OBD1 injectors on ebay, but not the reverse. My car is 100% stock and I do not want to hack its harness. I would prefer to steal wiring from a junkyard car and make a harness or buy one premade. Does anyone know of someone who I could contact who already makes the harness adaptor, or if I could do it myself from a junkyard source?
What honda years and models should I look at in the junkyard to get the correct connectors for teh oddballs (OBD2???)?
96 and up V-tec for the Female connector?
Where do I source the male OBD1 style connector to plug in my harness?
Thank you for any help you can provide.
OK so I got some quick help over at D-series.org on the same question. Figured I would post the answer here in case someone finds my thread and needs a similar answer.
So I was looking at the above connectors link...
I found the female one for my OBD2 injectors...it actually says it mates with honda injectors 1996-2011
HON-F2 Honda Style Female Connector
But is this the right male one to connect to my stock harness? It calls this the Bosch EV1male connector
EV1-M1 Male Connector
Thank you!
Yes they are OBD2 injectors
No they wont plug up without modification or an adapter harness which many places sell
The plugs you need are going to be from any 96+ honda.
You did your research well
These are the 2 styles
OBD1 on the left OBD2 on the right
Also these people have the connectors you need
Fuel Injector Connectors
Thank you!
